Configure the forwarding database global timeout to age out dynamically learned forwarding information.
- In the navigation pane, expand
- Select VLANs.
- Select the FdbAging tab.
- Type an interval, in seconds, for aging out dynamically learned forwarding information.
- Select Apply.
FDB Aging Field Descriptions
Use the data in the following table to use the FDB Aging tab.
Name |
Description |
FdbAging |
Specifies the timeout period for dynamically learned mac addresses on the vlan. The default valus is 300. |
